If its cold outside it will hold a higher rpm to warm the Jeep up quicker until it reaches optimal temp and will slowly climb down.
The main purpose isn't to warm the car up quicker, in fact the additional 1,000rpm doesn't do much at all for temperatures without a load. And the temperature it does gain is merely a side affect from the real purpose:
as stated above... nothin to worry about... it's not just your jeep, its most big engines. Theres a reason they say to "warm up" your car before driving it. with the big 6.1, all the oil, coolant etc needs to warm up to a good fluid temperature. as its cycling thru the engine it's getting hot, then dumping back in the pan with the colder oil. but once it's all cycled thru and warm, you'll get that nice smooth idle. gotta remember. after sitting for a while, the engine oil as all dripped off the rods, cam, crank, pistons, etc back into the pan. all that stuff has to get lubed up again on start
It's not "most big engines," it's actually all modern fuel injected engines (Modern being post 1990ish). The high idle's purpose is not to warm up components at all, in fact it drops down to normal before oil temperature gets anywhere near operating temperature. The purpose is, as you eluded to, cycling the oil, but not warming it up. Also, stop listening to whoever has been telling you to "warm up" your car before driving it, probably the dealership so you have to buy a new motor faster. Warming up a car in the traditional sense, letting it sit at idle for 20 minutes, is godawful for engines. You should drive it as soon as you start it. Start it, put it in gear, and go. Do everything possible to keep RPMs low while driving, under 2-3,000 for sure, but get some load on the engine. Also, try to minimize cold shifting as well. You shouldn't redline it, or go anywhere close, until oil temps are north of 150.
Yes, exactly what you said. It's almost as I'm tapping on the gas pedal but I'm not. In the BMW 335i world this usually meant faulty injections. I'm just wondering if this is normal or should I be concerned at all. Thanks.
I doubt it's the same, the injection problems in the 35 series are stemming from the high pressure pump used for the direct injection setups, which have been problematic for the turbo 6s since they came out. As for it being normal, I can't honestly say I've ever observed my Jeep do it, but I put mine in gear as soon as I start it, so I wouldn't really know.
