1 - 7 of 7 Posts
New to the forum thought id get some tips/opinions on what to look for in a used jeep. I currently have a v6 dodge magnum so this move to the srt8 for graduation will be great. I'm new to the jeeps but my old man had a 08 srt chally so I'm kinda familiar with it. also ive been saving and have about 10k saved up I'm thinking a 426 kit and a viking nag1 or a kenne bell and a nag1. Theres a cobalt ss in town thats running 11's and the only car to ever beat him was a supercharged ls3 camaro so what would be my most bang for the buck thanks! :)
Look at the transfer case.
Definitely! Also take a look at the entire driveline. I bought my 06 used, transfercase was messed up and the differentials/mounts were all in beat shape. Thank god I bought the extended warranty for the truck, had the driveline completely replaced, practically payed for itself lol
Discussion Starter · #4 ·
so what would it look like if it was good vs beat on? like dents and such?
· The Traveler
Check for any vibration @ 70ish mph. If factory goodyears are on it check the front inside tires for separation. Check the driveline out well, make sure it drives/shifts good. Maybe inspect the drive line fluids to make sure maintenance was kept up on.
The best way to check: get a well-season mechanic to have a look at it, preferable one that you know personally and is willing to take a good look.
The terrible half-assed way: put the truck up in the air, make a fist and hit the drive shaft or differential (decent amount of force. Don't make a blow with everything you got, you'll break a bone). If it shakes/vibrates violently, probably not road worthy since it'll do the same when you hit a bump in the road.
LISTEN TO THE CAR WHEN YOU SHUT IT OFF. Open the door while the truck is on and shut the engine off. If it makes a weird metal clanking/cracking noise, tc is definitely bad. Here's an example of what I mean, go to 0:47:
http://www.youtube.com/watch?feature=fvwp&NR=1&v=Evki6U9BNPI
1 - 7 of 7 Posts
