1 - 7 of 7 Posts
Ok how hard is it to replace the water pump?...I know the part is not expensive...and also is this a continuing problem with these vehicles
Premium Reformed Member
The only time I've seen it be a continuing problem is when people put a bigger radiator cap than 18 lbs on there. A 19 lb or larger cap will blow the seal on the water pump.
So how hard is the replacement of one...every water pump i have taken of vehicles have been a pain in the a$$.
It actually wasn't that bad. It took me about 4 hours to do
Will i have to remove any of the front end componets...via radiatior or fan assembly...or is it just remove the pump and thats it??
Discussion Starter · #7 ·
Remove the fan shroud and the belt then unbolt it.....I think thats it? its been 2 years since i did it but it was no big deal.
Newfie.
Alright thanks man...im gonna tackle it next week
1 - 7 of 7 Posts
