1 - 19 of 19 Posts
I was looking on the vreds website, and I noticed they have the sessenta run-flats? I'm scared to go with run-flats again because right now I cant even drive my rig because of the really bad separation problems with the goodyears, I can see into the tire on at least 3 different tires. Would any of you recommend the vred run-flats or which vreds should I go for, the SUV sessenta? Any advice for all of you is greatly appreciated, thanks.
I didnt even know they made run flats..but i dont think anyone on his forum ran vred run flats...again im not sure.
Go with the Vred Ultrac Sessantana SUV 275 for the front and 315 for the back, I run those with 20" stockers staggered. 9 in the front 10 in the back....you will have no problem with them. I've been running them for a few months now and love them they are great tires
Most of us got rid of the run flats cause they ride like shit. Much better ride on the non run flats.
Snail On Board
How much are the run flats?
285 is the width, the 40 and 35 are aspect ratios which when used in conjunction with the 275 and 315 respectively, tells you the height. So whether or not the first number is a 200 or a 400, it is the 2nd number that tells you how tall it is.
Snail On Board
Thanks for the info.
Anyone running vreds on 22's?. Looking at ordering some but not sure of the required height. Assuming the 275/315 combo would still work width wise?. Any insights are appreciated.
Thanks fellas!.
Hey I just put these on yesterday and they look awesome! I have a tire rub though in the front. I have Eibach springs and bwoody end links. Any experience with this? Anyone? Thanks all.
Can't recall ever hearing about it on the front. A couple brands will rub the link blots in the rear unless you use low profile headed bolts. Are your end links installed correctly?
Winter/Snow
Sir,
Are the Vreds okay for the winter/snow? I've had the nittos for 2 years now and they were pretty scary last year during the winter here in CO. I need new tires and the Vreds look pretty sweet. Thank you
Sir,
No the Vreds are only a summer tire and should NOT be used in the winter/snow bro.... You need a set Blizzak snow tires.....
1 - 19 of 19 Posts
