1 - 20 of 26 Posts
Discussion Starter · #2 ·
HOT! BUY! Custom Box W/Amp,Speakers,Battery,Cap
Beautiful a must see!!! Custom pattern to match the seats, A very sleek design! Box comes with Kenwood kac 1023 amp, Two L7 Kickers with grilles, Audio Battery, Fuse Block, Cap, and wires.
I want 2500 firm! Take a look at pics you won't be disappointed!
Vehicle Car Vehicle door Trunk Automotive exterior
Car Vehicle Vehicle door Automotive exterior Trunk
Motor vehicle Vehicle Vehicle audio Car Auto part
Vehicle Car Vehicle audio Trunk Auto part
Land vehicle Vehicle Car Trunk Vehicle audio
$200 shipped to Toronto Canada zip is m4b-1a8 LMK ?
Discussion Starter · #13 · (Edited)
H10 4300K FOG LAMP Xtreme Digital HID Conversion Kit
H10 / 9145 4300K Xtreme Digital HID Conversion Kit thin type THAT MATCHES HEADLAMP COLOR, Cost me $199.99 from http://www.kbcarstuff.com Which I believe is Xeondepot. I am selling the kit for $90.00+ Shipping, I recently sold my jeep and removed the kit out. Had them in there around 6 months have no use for them 100% working condition.
202 Xtreme Digital HID Conversion Kits
The Xtreme Digital Xenon HID Conversion kits utilize cutting edge Xenon HID components made with superior Japanese craftsmanship and quality to offer you the latest in High Intensity Discharge (HID) Xenon technology. To ensure optimal light output, the Xtreme HID Kit uses laser calibrated bulbs so that the focal point of the HID bulb matches the focal point of the corresponding halogen bulb. This will result in both proper fitment and optically correct beam patterns. Industry leading AMP style connectors are used to ensure proper water tight connections between the HID bulb and HID ballast.
The Xtreme HID bulbs utilize Philips UV-blocking quartz glass to filter out the ultraviolet rays that are potentially damaging to modern automotive plastic head lights. These bulbs provide more light on the road as well as the highest level of resistance to vibrations, extremes of temperature, and risks of explosion. Lower grade HID bulbs do not use proper quartz glass to save costs and will end up damaging your vehicle's headlamps over time and burning out prematurely.
Our shockproof & waterproof slim line Xtreme ballast uses a German designed ASIC control chip which will enable the ballast to constantly monitor the HID bulb's power requirements. This is the same technology that is used in OEM grade Hella & Matsushita ballasts. Lower grade ballasts are not able to monitor the changing bulb power requirements on a "real-time" basis meaning that there will be a significantly higher bulb and/or ballast failure rate. The Xtreme HID ballasts used in this product are uniquely designed for aftermarket HID Xenon applications as they are completely epoxy sealed to protect against harsh weather conditions. In aftermarket HID conversion kit applications, ballasts are often mounted outside the headlight leaving them susceptible to water damage. The Xtreme ballasts are specifically designed for these applications making them the superior choice for your aftermarket HID conversion kit upgrade.
This HID conversion kit will include a complete wiring harness that will literally plug directly into your OEM headlight harness via proper mating connectors. The harness provided will include upgraded fuses and relays to ensure that the ballasts always receive a constant 12V. Powering ballasts directly from the OEM headlight harness can cause your HID lights to flicker on occasion due to the fact that the power supplied from the OE headlight harness can fluctuate. Halogen bulbs can accomodate this voltage drop as the light will just dim. HID lights cannot; as a result, they will flicker thus resulting in premature failure. Unlike many HID conversion kits on the market, our HID kit will use a dual harness set up that will provide each ballast its own fuse and relay. Should a fuse/relay ever fail only one side will be effected vs both lights going out.
Xtreme HID conversion kits are manufactured in an industry leading ISO and TUV certified high tech facility.
treme HID Kit Specifications:
Nominal Voltage: Dual voltage ballast system for 12V/24V
Bulb Voltage: 85 +/- 17 (V)
Bulb Electric Power: 35 +/- 3 (W)
Operating Temperature Range: -40 ~ +95
Storage Temperature Range: -40 ~ +105
Operating Voltage Range: 9 ~ 32 V
Inrush current (0-5msec): <4.5 (A) (Low Draw)
Reverse Polarity Protection:YES
Ballast Specifications:
Xtreme HID ballasts are designed with a patented multi stage safety feedback (M.S.S.F.) system allowing them to interact with the bulbs to determine optimal light output.
Xtreme HID ballasts use a patented self intelligent light output configuration (S.I.L.C) to ensure brightness stability and precise illumination colour.
The Xtreme HID ballasts are designed for both 12V and 24V applications.
Equipped with advanced polarity protection system.
Ultra Thin Digital Ballasts!
$90.00+ Shipping, Free Local pick up.
Joe Bertrani
Pod and gauges still available ??
Sent from my iPhone using Autoguide
How much for shipping to 77088 Houston ??
1 - 20 of 26 Posts
