what do you guys think about this statement? my jeep only has the typical boltons but i was thinking 84mm would be a good idea anyway??
"HEMI TB SIZING RECOMMENDS:
My Standard Modified Hemi TB is an impressive improvement over the factory Hemi TB. It is absolutley perfect for most applications. This TB covers everything from bone stock through the typical bolton additions like aftermarket Air Intakes, Exhausts, and Programmers. My Standard Modded Hemi TB is an excellent value and will improve your performance nicely.
I do offer the bigger 84mm Hemi TB. It is meant for built motors of the next level which require more cfm than my Standard Modded Hemi TB can deliver. This means Ported Heads, Cams, Stroker Motors, and Boosted Applications.
While the "Bigger is Better Theory" is always an evil temptation proper TB sizing does not work this way. All you need to do is match your motors air requirements. Going bigger than necessary is not going to give you anything extra. Follow my recommends and get a good result."
