i will start by explainging what all is going on with my rig... then i will go over the mods done to the truck. i just got my jeep back form the dealer, they put a new transfer case motor in and took out the "disable 4WD switch" from the previous owner. when driving home it didn't quite feel the same to me (they did have it for a week so i was driving a different vehicle for a little while) so anyway i parked it at home. i just got a predator so i was wanting to marry it up to my jeep and start playing. the predator told me that my jeep had a previous tune and it could not back up my stock tune.
i didn't do anything else with it, left that night and it was running rough at idle and actually died out on me... so i fired it back up and same thing... i got it going and was heading down the highway with the cruise set at about 75MPH. seemed to be running fine. all of a sudden i felt a loss of power and the red lightning bolt hit the dash and the pedal had absolutely no response. i pulled over to the side of the rode turned the jeep off and started it back up... it was running rough but i put it in gear and took off ( probably not the smartest... but i had to get it back home) it took off like a bad out of hell! now it dies out on me every time i come to a stop. it will idle rough... as soon as you put it in gear it wants to die.. ANY HELP WOULD BE GREATLY APPRECIATED!!
Mods: Magnaflow exhaust, Hooks headers, indy stage II heads, PPP Ported Intake, MM ported throttle body, comp cams custom cam, 80lb fuel injectors, dual walbro fuel pump.
