Hey guys, just wanted to let you know that we have our old friends back in the game and making the best rails in the HEMI industry again! We're having some made as we speak and are currently taking orders for them. They are available in two std finishes, black anodized and clear anodized. (old rail logo shown on black and clear anodized rails, new logo shown below on blue anodized rails)
For an additional charge we can have them customized to your liking!
Aren't these hot!
"The finest fuel rails ever produced for the Hemi engine. We start with a SOLID BLOCK of aircraft grade 6061 aluminum and fully machine every feature to perfection on our five axis CNC. Our rails incorporate machined-in mounting tabs completely eliminate tab failure common on fuel rails with sheet metal mounting tabs."
FEATURES
The ONLY fuel rail designed and manufactured from a solid block of 6061 aluminum for perfect fit.
Integrated mounts for safe and reliable injector seating.
Two 1/8 NPT ports for fitting fuel pressure gauge or fuel supply for nitrous.
Permits use of OEM Fuel Rail Pressure Sensor (or can be blocked)
INCLUDES
Driver side fuel rail
Passenger side fuel rail
Stainless steel mounting bolts
FITMENT
5.7-6.4L Hemi engines with OEM intakes and forward facing throttle bodies
Doesn not fit with Kenne Bell superchargers (requires significant modification)
Contact [email protected] for consultation on custom intake manifolds
SPECIFICATIONS
Bore: 16.5mm
Port size: #8 o-ring (female)
Auxillary ports: 1/8 NPT (plugs NOT included)
REQUIRED ITEMS FOR INSTALLATION
Aftermarket fuel lines (or OEM line adapter)
Crossover line (or y-block)
1/8 NPT plugs (or connections to auxiliary ports)
We are running a special for them right now on them for $270 Shipped in the lower 48s. Add in the complete Hemi OEM fuel line adapter kit with front crossover for $149!
Give us a call if you have any questions about their products! We also carry the full line of their products as well, we are even thinking of a new project with them too! More details on this later...
Skip
Aren't these hot!
FEATURES
INCLUDES
FITMENT
SPECIFICATIONS
Bore: 16.5mm
Skip
