(I did some searches but never really found a good answer)
To those who are SuperCharged and those going that route. I have basically a stock motor and I am putting the ProCharger on this spring. I plan on going with the Dual Walbros because the flowcharger doesn't look to be a good route. I also wondered if I upgrade the injectors and fuel pump before the supercharger is installed will I still be able to run on the stock tune and motor? My plan was to install all this prior to bolting on the SC. (AF guage+Fuel Press Gauge). I wanted to run the fuel setup to make sure I had no problems first.
What are a good set of Injectors to use?(only plan on 6-7psi range)
Should I be changing the Spark Plugs?
Thanks
Thanks
