1 - 2 of 2 Posts
Whats up guys... I am all in on building a ~800 rwhp single turbo jeep over the next couple months and want to know what i am getting into. I am curious if anyone has insight on what I will need to upgrade. I am planning to build the engine, mainly wondering what needs to be upgraded driveline wise. Can the transmission handle this much power? What about axles/ transfer case? Any other parts that might fail? Anything help is appreciated, thanks. -Ron
BlaBlaBla
Interesting first post.
The transmission will last only as long as you want it to. Meaning if you beat on it or race it smoking the clutches will happen. It’s usually 3rd gear that goes first.
The transfer case will be fine as long as proper maintenance is done.
The rear end is like the transmission. It will wear out. The timeframe is commensurate to the amount of abuse. I would install a wavetrac at a minimum.
[email protected]
1 - 2 of 2 Posts
