1 - 7 of 7 Posts
Does anyone know which one is a reverse wire or signal from this harness
The 3rd connector down on the page is the only connector that I've found for the shifter assembly. Hope this helps!
Discussion Starter #3
Thank you krazy8 doesn’t look the there’s a reverse signal there, i have an Ipad for a radio and i added a wifi back up camera and need a reverse signal to trigger the camera. I guess I’ll have run a wire from the reverse light to the front.
ruben
no, you wont... well you might LOL depending on your situation but
I installed an aftermarket deck in the jeep, I believe the trigger for the backup cam is located on the harness for the factory radio.. IIRC there are a couple of harnesses that go into the head unit, I had the NAV so that might differ from yours however when the installer put it in, I do not think he touched the shiftgate wires at all!
check the pinouts behind the factory head unit!
Discussion Starter #6
Thanks everyone i just ran a wire from the reverse bulb instead, added this WiFi camera unit since I’m using my iPad mini as a head unit
Discussion Starter #7
1 - 7 of 7 Posts
