1 - 5 of 5 Posts
I noticed my coolant was a little low and I was in a fairly remote spot. I topped it up with that will mix with any color shell antifreeze wondering if I should get it flushed right away or if I will be ok. It wasn't much but I have read that mixing can cause gelling... the last thing I want. Please let me know!
Thanks guys,
TH
Doesn't specify. Sucks as i just had it flushed/changed but I don't want to mess around. I will just get it flushed...again lol. This time I am going to get a jug of the pink stuff to go.
That guy..
How much did you put in? Im sure it will be fine..
Wasn't much Rocky. It was just below the add line and I filled it just shy of the full mark. According to the SAE 15% is fine. I guess the gelling is the result of mixing green (silicate based) with pink. The organic acid precipitates the silicate. I am thinking I should be ok.
1 - 5 of 5 Posts
