Yes. You'll need a shorter belt.
Unless someone knows the part number for sure. If not I would wait until tomorrow and call Vortech during normal business hours and have them give you the right part number.....OK, this maybe a dumb question, but what is now the correct part of the pulley for me ?
I looked up at the vortech homepage and i thouht this pulley would be the correct one:
http://www.vortechsuperchargers.com/product_variation.php?pvk=280
This one don´t have Tooths .... .
Or is this not the correct one and i should use another one ?
Thanks for the inputs ... .
Any hints for the correct length of the belt and where to get ?
Thanks,
Take care
Thomas
No worries.... Yeah the one from Speedlogix is the Cog pulley, which says 28T on it... From what I have seen that is the one you should change.... I will have Paulo confirm it for you in a second......Hi,
Yes - but calling is not so easy for me since i am located here in austria and we have a time difference.
What i don´t get is that the pulley which is shown at the Vortech Website is a 6-Rip Pulley without any tooths:
http://www.vortechsuperchargers.com/product.php?p=42
And this one from the speedlogix store has tooths:
http://www.speedlogixstore.com/product_p/4gr033-028.htm
Do i have to change both pulleys ?
Sorry, i am confused
Thanks,
Take care
Thomas
If you want to go two sizes smaller then you want a 28 tooth pulley this is the cog drive pulley that is directly off the supercharger head unit. I hope you are planing on tuning for this cause as far as I know only two guys here run this pulley and it's quite a bit of boost for a stock bottom end.Hi,
Thanks,
Take care
Thomas
just did it about 2weeks ago...had to replace both pulleys and belt.....but also had probs with the fuel pump your running ....i had to upgrade to a fuelabs pump....and have it pro tuned on a dino
