I've tried to massage google and the forum and can't turn up much to an answer for this issue.
I have an 07 GC SRT8 - this started months ago, but rarely and was very random. Unfortunately it has become more consistent and is starting to get to be a real PITA.
Issue: with the keyfob I can unlock it with fob, drive away, stop at a location, get out and the Jeep, and she won't lock with fob.
Or maybe the next time, drive, stop at location, it will lock with fob, but when I come back, it won't unlock with fob. In which case I need to manually open with the key, set off the alarm and start the car.
I have two fobs and it will do this on either. I've replaced the batteries on both, they are newer type fobs so no solder joints with the connection around the batteries coming lose, no solder joints messed up, and I even slightly bent up the contacts that are on mine that come in contact with the battery and circuit board to ensure good connection with the battery. I truly do not believe it's a fob problem since, if one is acting up when I'm at home, I'll go get the other to see if it works. Same results - neither will work.
Tonight it did this - I remote started it with fob, ran it 5 or so minutes to warm it up, and then went to leave and it won't unlock with the fob. So now I need to set off the alarm with opening it up with the key. I drive away to the store and turn it off, get out, and this time in locks with the fob. I go shopping for groceries (30min) and come back out. It won't unlock with fob. Set off alarm, start car and head home.
Get home turn off car, open and close door simulating getting out, fob in hand, jeep locks with fob. Wait five minutes, jeep unlocks with fob. Lock jeep again, wait 10 min, auto start - wait 5 min, jeep unlocks with fob.
This problem is killing me - what the HELL. Have you guys any idea before I have to pay the rapist dealership money to have them diagnose it?
One of the goggle searches said something about a TSB for 2010 model year having issues with the keyfob controller and needing it updated/flashed, or the only other thing I've seen is where the older keyfobs had the battery holder soldered to the circut board and the solder joints would come loose. However my two keyfobs have the battery holder on the plastic end with to metal prongs and on the circuit side four small metal prongs that touch the battery. Looking over both keyfobs I see nothing that points to the fobs one bit.
Read every post in http://www.cherokeesrt8.com/forums/showthread.php?t=37562 and am just as lost as when I began. Some say it doesn't deal with older vehicles, some have found it does. What a freakin overall pain. Makes me not want to drive it, unless I drive it like its stolen!! (every time I have to set off the alarm
