1 - 6 of 6 Posts
Any ideas I don't want to break anything...
there should be a clip that removes the mirror from a little bracket that is glued to the windshield. I'm not sure how easy it'd be to remove that bracket as it is on there pretty good. However, dont forget about all the wiring that you'll have visible without the mirror there. I'm not sure if the wiper sensor power is tied to that at all or not...
Discussion Starter #3
Thanks, I just wanted to mod my radar screen inside the mirror should be fun! Yeah it's in there pretty snug so hopefully I don't break it!
OH! I thought you wanted to remove it for good. in that case you should be able to stick a small screw driver in there to pop the clip on the bracket that hold the mirror arm. Then it kind of just slides off. shouldnt be too difficult. good luck!
1 - 6 of 6 Posts
