1 - 5 of 5 Posts
Sorry if this has been answered before guys ive read post but seems ones had the problems im having. Last night I tinted my tails and fogs (finnaly) and decided to put in some leds replaced stop and turn with a 3157 spider led and a 15 led 921 for the back up and added 2 6 omh restiors. I did a test run before istalling all by installing one of the 3157 "still had the the other bulbs pluged in" and it worked like a charm. So after installing them all none turn on at all only the third brake light,the fronts work but oneside hyper flashes not the other?
what model year? 06 had 3 bulbs, 07+ had 2. so its different.
resistor attached to the OUTER wires of the 3 wire plug for 07+ or across the blink and the ground on the 06?
if this is an 07+ you need the CK type bulbs; see v-leds for an explanation.
Discussion Starter #3
Sorry its a 07 attached resistors to the first and last wire of the harness
yeah ok. you blew a fuse under.
you need a CK type 3157 bulb
you could switch the 2 outer wires; move the ground and the major, and then your regular 3157 LED will work.
Discussion Starter #5
Ok Ill try the moving the two wires and the major. I pluged in the halogen 3157 and they work so no fuse blown
1 - 5 of 5 Posts
