1 - 9 of 9 Posts
Can the opening height of the rear hatch be adjusted, when it is in the garage it opens to high touches the open garage door and auto closes, I need a few inches less opening. If so how or any other suggestions.
As it's going up, just pull on the trunk latch release lever again, this puts it in manual mode and you can open to whatever height you want.
Probably your answer right there
Reactions: fastlane1
Just out of curiosity - does it remember this setting like some GM liftgates? Or is it something where you tel it to stop only this time, and have to do this every time you use the liftgate?
Just tried the second pull thing to knock off the auto up and it works great, Thanks!
Now I can pull in my garage and unload stuff from the rear without trying to keep it from banging on the garage door overhead.
1 - 9 of 9 Posts
