1 - 10 of 10 Posts
When i passing a car the rearend whined but it robbed the power. Took it home pulled cover and didnt see anything and the backlash was .008. sealed up and took off again still doing it......is the to do with the bs torque management stuff......cuzz while cruising hear nothing and turnning nothing....only when trying to get on it....? ideas? thanks
How do you check the backlash? What is acceptable?
The whine with TC off is normal.
Discussion Starter · #4 ·
I just go off what rule of thumb .005-.010 give or take...... Ten for high milage.. Pulled cover set up my dial indicater staret .015 travel and mag base on ring touching pinion gear and have someone turn shaft till solid contact..... Don't hold it to me but that's what I use also at work for our gearbox fin fans (.003).... I'm a machinist for BP....
Do you have non-stock tire sizes?
Discussion Starter · #8 ·
Yeah... It's got stockers on rear and some yokas on front I'll get new and see what happens thinks.... Feel silly for not catchin that... Thanks I'll post up what happens
What are those front tire sizes? Front and rear tire diameters must differ by no more than 5% or you can kiss your TC goodbye.
1 - 10 of 10 Posts
