1 - 11 of 11 Posts
Hey fellas i think i need new rear bumpstops, i bottom out more often than i should, then when i went to put on my R1's i noticed the bumpstops were gone from the tower, and found on the other side the bumpstop was gone as well and found a piece of it inside the spring, i believe my set up is original stock. here is an eh not too bad pic of it in the background..
also where can i get new ones or better ones for the stock set up?
Discussion Starter #2
bump for bumpstops
BUMPstop this one for me too !
I've been through endless bumpstop threads .. im lost b/c I had my eibachs installed and am now unsure exactly what the shop did as some parts were used and some not :(
in for some info on this one !
Discussion Starter #4
yeesh BUMPSTOP!!! FOLKS can we get some assistance lol
Premium Whore (Lifetime)
For you:
http://www.moparonlineparts.com/partlocator/index.cfm?action=getJointLocator&siteid=214954&chapter=&Sectionids=24,2788&groupid=20135&subgroupid=60178&componentid=0&make=17&model=Grand Cherokee&year=2007&graphicID=T048110&callout=4&catalogid=1&displayCatalogid=0
And for you...
For the rear Eibach sends you a big spacer/tower, a small cup and a bumpstop.
DO NOT install the big spacer/tower.
DO install the small cup and bumpstop.
From this thread:
http://www.cherokeesrt8.com/forums/showthread.php?t=56164&highlight=eibach+spring+install
And another usefull thread:
http://www.cherokeesrt8.com/forums/showthread.php?t=45525&highlight=eibach+spring+install
Hope this helps
you rock !! definitely need to go back to the shop and have that taken out ... my back cant handle this any longer lol
Big thanks again !! :D
Just a thought has anyone called and tell Eibach to stop sending the large spacers ?
My bumpstop is busted in rear too, how do I change it , im looking at it now, thx. I got it , PITA but it's done w/o dropping the rear spring.
Nobody has tried to install a set of air bumpstops yet? You can get them for like $100...
I don't know if there is room, or how one would install them but with all of the complaints, I figured I would mention them.
1 - 11 of 11 Posts
