1 - 10 of 10 Posts
Can't tell where the noise is coming from but I have a rattle under slight accel. It's only from 1,000 to 1,500 rpms and it's only coming from the left front of the Jeep. I can't hear it when the windows are rolled up. I had taken it to the Jeep dealership and had one of their techs look at it. First thing he did was hit on the converters and it rattled a bit. I thought thats what it was but it didn't seem loud enough. They replaced the converters and it didn't help. It's been going on for some thime now and it's a real pita. Its an 06 with 43k.
Thanks
Discussion Starter · #2 ·
Well it's not the cats. Cats had a rattle and the dealer replaced them, well rattle is still there and yay now I have an exhaust leak.
Make sure all the bolts are tight. There shouldn't be any leaks.
Discussion Starter · #4 · (Edited)
Yeah I went and checked the bolts that connected to the cat-back. One seemed real loose and I tightened it. No more leak for now. I still have that stupid rattle though. Its underneath the Jeep. Who knows?
I had the same thing in my 08, it was either the mufflers or resonators
Probably something loose inside one of the two
Got fixed by installing a B&B catback :D
HP - how loud is it? Maybe try to get a video of it to post. I have heard of some guys temporarily mounting a GoPro camera under the vehicle and drive it. It helps find squeaks, rattles and stuff that don't happen while just sitting still.
Discussion Starter · #7 ·
It's pretty loud. If the drivers window is up and the passenger window is down you really can't hear it, only when the drivers window is down is when I hear it and it's all the time. I mainly hear it when I'm on normal take off from around 1,000 to 2,000 rpms and in the same range when I come to a stop. If I rev the motor no rattle at all. I'll see if I can get it on video later this week.
Discussion Starter · #8 ·
Problem solved. Took left front wheel of and found the little dust shield behind rotor had a rock stuck to it that was bouncing off the rotor. The rock had tar like substance stuck to it.
Great news. Feels good to resolve something like that doesn't it!
1 - 10 of 10 Posts
