The problem with ethanol is chemistry....
Your engine is nothing more than a big chemical reactor. It mixes fuel (gasoline) with air (roughly 21% Oxygen), reacts them into new compounds (mainly CO2, CO, and H2O), and uses the exothermic heat energy released during the reaction to drive the Pistons. Some may call the rapid oxidation of fuel... "Combustion".
So the amount of energy that can be released in a combustion engine is entirely dependent upon WHAT IS BURNING. If we assume that displacement, RPM, and intake pressure (boost/vacuum) are constants, meaning that they don't change for any given apples-to-apples comparison, then the only variable is the fuel composition. For instance, propane burns hotter than natural gas, a Butane lighter burns cooler than both...why? Because the chemical reaction of oxygen breaking down the fuel is what is releasing the energy. When the oxygen combines with the carbon in the fuel, it breaks the covalent bonds of the carbon and hydrogen. The number and and type of covalent bonds broken for each type of fuel determine "how hot" it burns.
Take a shot of 100 proof vodka and light it on fire. Notice you can put your hand over the flame and it likely won't burn you. Now do the same for an ounce of diesel (not recommended). The ethanol in the vodka is a cool flame, very low energy, because the C2-H5-OH composition of ethanol has only a small number of single covalent bonds, and thus less heat is released when it burns. The diesel on the other hand, is a long-chain hydrocarbon with several triple covalent bonds, and releases much more energy per volume.
Bottom line, ethanol has LESS ENERGY in it per ounce than gasoline of any type. You will always get less power from ethanol, worse mileage, and poorer overall performance.
On a side note, Some alcohols have different colligative properties such as resistance to detonation (octane equivalence) which makes them suited for extreme boost applications.
