Installed this setup Saturday. Bedded using 3 sets of 8 to 10 quick near stops from 60 (my neighbors thought I was nuts), with ~20min cool down between each by driving around without pressing brakes. After final set, parked the Jeep for the night.
Today, took the Jeep out and drove around for awhile. First thoughts are that on initial braking, there is not as much bite but that this feeling quickly goes away after additional brake pressure.
Then I put the car through a series of hard start and stops of different speeds up to 100mph. Brakes felt very solid with none of the initial soft bite feeling. I was timing these stops at a place where I needed to make a u turn to force some pucker factor should the brakes fade too much.
Then I did a few 60 to 0 and used the in-dash gauge. Results were:
1st stop: 135ft
2nd stop: 130ft
3rd stop: 132ft
Each of these stops were cruise at 60 and then mash on brakes letting ABS kick in as needed. I expect these number will get better over the next few weeks. It would be interesting to see what others of you are getting for 60 to 0 numbers.
Overall, I am very satisfied with this setup.
Parts:
PS.58003 Premium-Series Diamond Slotted Disc Brake Rotors:
PS.58004 Premium-Series Diamond Slotted Disc Brake Rotors
309.10530 Stoptech Street Performance Disc Brake Pads
309.11490 Stoptech Street Performance Disc Brake Pads
1st stop: 135ft
2nd stop: 130ft
3rd stop: 132ft
Parts:
