1 - 5 of 5 Posts
So I been looking at replacing tie rods to see if that will help with my sloppy steering. I noticed on rock auto that all the replacement parts are greasable ones, are the factory one too? Could this be the reason for sloppy/floating steering? Also looking at doing upper and lower ball joints too, is this a point I should address as well to tighten up the front end?
Alignment is in spec, brand new nittos that road forced under 5 and stock height. Sloppy is very spongy and not quick in response, at high 80 if I let go of the wheel it drifts back and forth and I can turn the wheel to 1 - 11 with no response. It feels like the front end end isn't even really there and it's kinda frightening to drive cause I don't feel in control. There is also vibe in the wheel a lil too.
Our 2010 has no grease fittings. I see no problem with replacing with grease fitting equipped replacements as long as you maintain them. I drove vehicles for 40 years with front end components with grease fittings and if you regularly grease them they essentially never wear out under normal use.
· Straight Up Beast SON!!!
At 8000 miles the stealership replaced my outter tie rods cuz they said they saw play in them.to try and fix my vibration issue at 70 mph.... I say if everything in the suspension looks tight then I would suspect the steering gear box is probably at fault....
1 - 5 of 5 Posts
