Also will need the jeep wiring harness for the BAP to make it work for your truck, make sure that the blower is clocked the same as in the jeep kits as all blowers aren't clocked the same, the intercooler mounting may also be different if it is the same intercooler, you will def need the correct piping for the kit as well, sounds like a big project to be honest, oh and don't forget the crank pinning kit as well, so your missing a lot really...could get costly, the brackets aren't cheap to begin with...
At this point you're almost better off getting a jeep tuner kit and adding the stage 6 fuel upgrade, map, injectors and tuning...that way your knocking the guess work out of it...would you like me to pm you pricing on the jeep kit? Were running some sweet deals currently...
