Status
Not open for further replies.
1 - 20 of 25 Posts
SOLD!! SOLD!! SOLD!!
For Sale: Lowered Price to $2500+ shipping from $3000
Paxton Supercharger Tuner Kit made by GSM.
GSM provided the brackets, hardware, and air tubing. I have upgraded to a larger radiator/heat exchanger for the water to air cooler. Coolant hoses and pumps are Vortech brand.
Performance:
This set up was pushing 6.5 - 7 lbs of boost.
I never had a chance to dyno, but I did run it a couple of times at a 1/8 mile track. Would get high 7s, low 8s. And this was on a completely stock engine, exhaust, and drive-train. Also on 22 inch rims that doesn't help for speed.
Parts included in the KIT:
Paxton NOVI 1500 Supercharger and brackets, pulleys, and hardware
New Napa Gates Belt and Old belt still good
BWoody Manual Belt Tensioner
52lb mopar injectors
2 BAR MAP sensor
Kenne Bell Boost-A-Pump and boost sensor switch
Water to Air cooler, piping, couplers, turbo style clamps, hoses, water pump, wires, fuses,
Upgraded larger radiator/heat exchanger
SSRT8 Aluminum Engine Covers
14 BRAND NEW Iridium NGK 5107LZTR7AIX 2 steps colder you will need 2 more
You will need:
- Adapter from the engine to the SC feed line.
- Small length of coolant hose from the radiator/heat exchanger to the water pump.
- 2 more Spark Plugs, I have 14 new spark plugs, 2 steps colder plugs.
- And the tune to make everything work right.
You may want to rebuild the supercharger with new oil seals as it has about 8000 miles on them, as a daily driver but not necessary. There seemed to be a little bit of oil in the air tubing when I removed it but nothing major. Turned out to be coming from the engine not the supercharger.
any questions please pm me thanks
Machine Vehicle Electrical wiring
Product
Automotive lighting Headlamp Automotive exterior Light Bumper
Auto part
Wire Electrical wiring Red Electronics Technology
Reactions: Pachy
Still for sale, PIC is finally up
There was some oil on the inside of the air filter and on the down pipe from the blower but not much. Before I removed it, it had a bad drain hose fitting from it that was leaking oil and had that replaced with a new one.
I'm def interested, i used to have one of this kits, i'll make you an offer as soon as i ge everything sorted here( if you have not sold it yet)!!
I see it needs an oil feed. Does this drain into the drain plug on the pan or where does it return to the motor?
How much boost did you make with this blower and how much power did it make? This sounds like a great deal.
Discussion Starter · #8 ·
The oil return goes into the drain plug on the pan. It comes with the fittings. Just missing the feed fitting and hose.
Reactions: Jack_Toepfer
Discussion Starter · #9 · (Edited)
Ok last but not least is the boost a pump. Finally had some time to take it off. The kit is all off packaged ready to ship.
Discussion Starter · #10 · (Edited)
Wires all the way back to the pump. Also connected a boost switch to trigger the boost-a-pump under boost. Some people run it "ON" all the time but it may lower the life of the stock fuel pump idk if its true.
Heres the whole thing packaged up ready to go...
Footwear Material property Shoe Auto part Furniture
Discussion Starter · #11 · (Edited)
Some more info on this kit.
This set up was pushing 6.5 - 7 lbs of boost. I never had a chance to dyno but I did run it a couple of times at a 1/8 mile track. Would get high 7s, low 8s. And this was on a completely stock engine, exhaust, and drivetrain. Also on 22 inch rims. Any questions let me know.
Discussion Starter · #12 ·
Bump!! Still for sale!! 2500 + shipping takes it.
Discussion Starter · #13 ·
Friday Bump!!! 2500+ shipping!! Best price for a SC Kit!!
Discussion Starter · #14 ·
Hump Day Bump!! Feed line now included with kit!!
Discussion Starter · #15 ·
monday bump!!! Best deal for a supercharger!!!
Discussion Starter · #17 ·
Yes still available. PM me if interested.
Discussion Starter · #19 ·
Still for sale, 2500 plus shipping. cant beat the price for some boost!!
Discussion Starter · #20 ·
MONDAY BUMP!! Need to Sell this KIT!!
1 - 20 of 25 Posts
Status
