i will give it a try tomorrow.Have you tried to drop the rear seatbacks down and see if it goes away? Some posts I read said it was where the seat locks into the bracket.
Yup have crickets as well in my beast and it sounds like its coming from the rear passenger door area. Take when I take off in the beast and don't hear it any other time while driving the Jeep.I have crickets too!
I know what it is (for my Jeep)
Its in my passenger seat - area. IDK if its in the rear but definitely cricket sounds in the front passenger area.
Its the factory door speaker squeaking in my case. I tested it by knocking on the plastic door panel with my palm. I could hear crickets when I knock around the speaker.
The factory speaker setup (if you dont have the boston acoustics upgrade) is crap!
Good idea man!If it's not the seat try bouncing the beast up and down with the engine off...if you hear it then it may be the parking brake cable rubbing on the rear diff housing.
THat is what's happening to mine. My JEEP is lowered that's why it's rubbing. I thought about re-routing the cables over the swaybar but I don't know if that's possible. I mean how would I even remove the cables? What did you do to yours?If it's not the seat try bouncing the beast up and down with the engine off...if you hear it then it may be the parking brake cable rubbing on the rear diff housing.
Thanks for the tip.It rubbed against the sway bar not the diff housing...simple fix...Here ya go bro...http://www.cherokeesrt8.com/forums/showthread.php?t=48580
Still working fine on my mine.
