Check the map sensor?
go back to the old pulley and old tune and go from there to rule things out.
Wouldnt I get a code if the map sensor was acting up? How should I check it?Check the map sensor?
What if your map sensor is 2 bar and your tune is written for 3 bar? MAP sensor is working just fine...Wouldn't I get a code if the map sensor was acting up?
My battery is good. Still new.. replaced it recently.Trinity, dashdaq, dashhawk or even better a scan tool (if you have a friend with one/cool shop) or replace it.
I would do the pulley and tune first though. Rule those out first.
How old is the battery? WK's are very very sensitive in their electronics
I dont know about that... I could look into it. But I didnt get a whole new tune. Just tweaked toe timing and fuel for a slightly smaller pulley.What if your map sensor is 2 bar and your tune is written for 3 bar? MAP sensor is working just fine...
Immediately after the parts were put in it started acting up.Was this immediately after you had the parts put in or a few days later?
I would also check all your vac lines and make sure everything is connected properly and nothing is pinched/blocked
Check the electrical connections to the trans and t-case (loose/dirty), input and output sensors too.
