1 - 4 of 4 Posts
any idea what this is related to or what the culprit would be? the codes been in the truck for about 2 weeks now. everything is running fine as far as i can tell.
I had this code a long time ago after I installed my bwoody. Turned out the one of the wires in the extension came loose. So I just plugged it back in soldered it. And its worked fine ever since. GL, hopefully its an easy fix.
Fred
Discussion Starter #3
hmm so its the iat cable? odd since i never really touch it and its the oem wiring...guess ill need to go to the dealer
any idea of the side effects of not taking care of it?
I would look it over before I went to the dealer. But if you have warranty might as well let them look at it. I doubt it has any ill effects, but I wouldn;t role with it for to long, and I probably wouldn;t do any WOT with it. But I doubt even if you have it would affect anything.
1 - 4 of 4 Posts
