1 - 6 of 6 Posts
Can anyone recommend what oxygen sensors to order? My AFR gauges are going crazy and I figured I would start by replacing them to see if that does the trick.
Discussion Starter #3
Oh really. Definitely just ordered four brand new O2 sensors, but I can return them. My AFR gauges work half the time and get all whacked out. So before I plug my tuner in I obviously want to have the correct AFR readout.
For your AFR gauges or for your jeep? 2 different types of sensors so please specify.
Hmmmm still waiting on the answer to my question. You can reply with 1 of the following:
(1) Jeep
Or
(2) AFR Gauge
Just so you know the jeep uses narrow band sensors(NTK) and your AFR gauge uses a wide band sensor(usually Bosch)
Care to explain AFR gauge “going out of whack” as well? Could be many things.
Discussion Starter #6
I did a little more digging around on the Jeep. It’s for an innovations gauge. I went onto there site and was able to locate what one I needed to order which ended up being the 4.2 connector.
1 - 6 of 6 Posts
