1 - 2 of 2 Posts
So had questions on the overdrive pulleys, is it worth the amount of labor, and if so what one to use for a wk1 supercharged magnuson with a cam.
Theres alot of different ones17% so on...what ones should I use if any?
Well if you want more boost and less slippage by putting on a smaller upper its the best way to go. I'd start with a 17%, you can always buy a new ring after the hub is on. Only drawback is now all your accessories are running 17% faster.
Sent from my SM-G960U1 using Tapatalk
1 - 2 of 2 Posts
