My fuel pump has no power going to it but have power at fuse and relay, is there anything between fuel pump and relay might be stuffed? or does any know if i can find wiring diagram so i can rewire power to pump. when i put power from a battery with wires straight to pump the car starts.
There is a major ground located towards the floor from where the FDCM is located. If you were sitting on the drivers side of the rear seat it would be located near your heal of your left foot. Fuel pump won't run if this connection is broken.
