also gonna relocate my battery to start making room for piupework for the procharger.. do you guys know what gauge wire i need to extend the battery wire to the rear cargo area?? gonna mount it inbtween the 2 nos bottles and behind the subwoofer. my rear wood piece i fabed up for the nos tanks is ready to go and im picking it up tomorrow. nos tanks will be on the far sides then im relocating the sub dead center but up close to the rea hatch then im mounting the battery right behind it in a vented battery box.... im siked
If you relocate the battery to the rear, NHRA rules says you must have an external shut-off switch in the rear of the vehicle.......which gets tricky with an SUV. I think the battery must also be in a sealed box, vented to the outside.
Master Disconnect Switch: Whenever a battery is relocated to the trunk or vehicle runs 9.99 or quicker or exceeds
135 mph, the vehicle must be equipped with an external master disconnect switch. This switch must be clearly
labeled and immediately disconnect the positive side of the battery. If switch is “push/pull” type” push must be the
action for shutting off the electrical system. To determine if the switch operates properly a tech inspector will turn off
the switch with the engine running. If this action does not immediately shut down the engine then the switch is wired
improperly and the vehicle shall fail the inspection. Drivers should ensure the alternator charge wire is routed to the
battery side of the switch. This isolates the alternator from the rest of the electrical system. Drivers should check with
the switch manufacturer to ensure it is properly installed. Refer to NHRA Rulebook section 8:4 for further clarification.
In all cases the master disconnect switch, including an OEM style ignition switch, must also shut off the electric fuel
pump(s) regardless of battery location.
