Congrats Dupre, your beast is finally up in the air with progress being made already
Now that's an idea.Sweet!! When is Stage 6 going to have a private track day with all their turbos?!
We'll be representing pretty hard in Bradenton.Sweet!! When is Stage 6 going to have a private track day with all their turbos?!
Yep this one will be running stock exhaust manifolds so it will be interesting to see how it does.Sweet! Can't wait to see how this one turns out!
That's what we are hoping. It'll just be nice to see the difference from the stock mannys to the header kits.Shouldn't be a problem, that's what we use to.
Enjoy te build!![]()
Just curious on this, but with the stock exhaust manifolds & say HB's SW headers would there only be a couple different connecting pipes or is there more than that. Would it be possible for them to swap out those couple pieces, if that's all there is, with some made from a jig from HB's headers?This will also be the kit that gets jigged for the production kits, so all you lurkers looking for a mail order front mount kit, get ready to buy some Turbo madness
Each header setup is a little different so the pipe routing would not be the same. Are you asking if you could modify a stock manifold kit to use with headers?Just curious on this, but with the stock exhaust manifolds & say HB's SW headers would there only be a couple different connecting pipes or is there more than that. Would it be possible for them to swap out those couple pieces, if that's all there is, with some made from a jig from HB's headers?
Yeh pretty much I guess.Each header setup is a little different so the pipe routing would not be the same. Are you asking if you could modify a stock manifold kit to use with headers?
Anything is possible. You would need someone to fab a different y-pipe.Yeh pretty much I guess.
so when is dyno day HB?We've actually got 2 Jeeps on lifts right now.It's about to be a busy few weeks. Could possibly have 3 on lifts by next week. It's about to be a juggling act of Jeeps going on now that the Viper TT is done and Chris' Jeep is done. It's full throttle for all the Jeeps in the shop.
