1 - 12 of 12 Posts
So thinking about deleting the suitcase muffler and resos, and replacing with a Magnaflow 12599 in place of the suitcase. It's described as having a "Tru-X perforated core."
Now, in the next couple months I want to do the Magnaflow high-flow midpipe "y-pipe" even though it has the x pipe built in:
Now my question is, would it be redundant having two "x's" basically in a row? Would I be better off going with two regular straight through type Magnaflow mufflers?
Thanks in advance for the advice.
It will be pretty quiet. I'd go with two 12867's. Are you leaving the reso's on ?
Hmm. Well I can tell you I had catless headers on with the 12867 singles and reso delete and it was loud as hell so maybe you should stick with the 12599. Although maybe with the stock headers and hi flows it would be okay ? Hard to say.
I just installed this muffler with reso delete! I love it! Nice rumble with start up and a great sound at wot! I left the resos in at first and sounded pretty much the same as stock to me but with the resos gone I love it! Great muffler! Imo
Daily Driver..........
I have the tru xpipe. i like it.
Discussion Starter · #8 ·
Thanks for the input, but does anyone have any opinions about two X's right in a row? What i am most concerned about. I know Magnaflow mufflers sound awesome on the Jeeps, just want to make sure I go w/ the best setup.
I was thinking of using the magnaflow tru xpipe and replacing the suitcase with two 12687's magnaflow rounds. I think I would leave the reso's on.
With this setup you wouldn't have to worry about having double x's, and way cheaper than a full system.
Has anyone run this setup?
Discussion Starter · #10 ·
Bump, I'm sure someone will have experience w/ a similar set up. I have no idea what (if any) effect double x's would have in back pressure, exhaust flow, and HP/TQ loss/gain
I still do not know what way shoule I go with my 426.
I have stock headers and do not want to replace them. Wanna add cut outs but in order to fit them weel have to delete mid muffler and save the resos or second way move mid muffler backward to make place for cut outs and delete the resos.
Will I loose power/torque without mid muffler as the backpressure will be different ?
What is best way ?
My goal is first performance than sound. Do not care about drone. It is hemi:)
1 - 12 of 12 Posts
