I have a 2014 that is all stock Harmon kardon. I am looking to upgrade the system without removing the stock. Basically I want to run a “shell” sound system. 6x9s in boxes to amp and subs to amp all running to the factory head unit. Is this possible?
I have a 2014 SRT with the stock stereo and a 2018 Trackhawk with the HK. The HK was better but I wanted more power like 2800 watts rms 😄 I used a PAC harness to run aftermarket amps that works with both as they have the same heads but the HK has different amps and door speakers. plastic...
The HK system is pretty good. Most people would just add a powered sub. However I wanted more so I went with a PAC harness that's plug and play to gives me rca outputs to connect aftermarket amps. interior panel tool And you get front/rear and their sub output if you want to use...
www.jeeptrackhawk.org
Related Threads
Cherokee SRT8 Forum
1.4M posts
46.9K members
Since 2006
