1 - 7 of 7 Posts
so i had the putco leds all around but the rear seats were very dim i went to change them with the 194 led from vleds they are brighter which makes me happy but now when i lock my car the rear seat leds stay light but very very low im confused anyone is having this problem anyone please contact me asap or pm me
Common problem with LED's.... Some install a resistor somewhere in the light circuit and others install a filament bulb in the rear hatch or the glove box.... Somewhere around here there is more info on this issue... I have Leds everywhere and did not experience this effect....
Reactions: SRTat3U
Discussion Starter #3
so the stock bulb that was in the glove box should cure this problem ?
Discussion Starter #4
when i had putcos all around i didn't have the problem its when i switched out the straight bulb in the rear to the flanks for optimized lighting they weren't putcos they were V-leds is when this began
Should cure it man.... That glowing effect happens for 3 mins if I recall and then turns off....
Discussion Starter #6
so if i left it the way it is and walk away and come back 3 mins later it will passively turn off ?
lol when i 1st installed the led's i started to freak out too thinking it would drain the battery..but its such a low draw it won't do much. I've gotten compliments because its gives off that low ambient light like in the new M3's
1 - 7 of 7 Posts
