1 - 20 of 26 Posts
I had a Jet tstat in my jeep for 2 years and needed to replace it because it went bad. I ordered a Motorad hoping it would be more reliable than the jet. When I pulled the jet out I found that it was stamped MOTORAD on the side.
haha, have you been under a rock?? :p LOL, just playing :D
Wanna get more confused? From autozone they are $14 to $18 bucks. Not priced like below.
http://www.summitracing.com/parts/JET-10183/?rtype=10
Also, the motorad (at least every one I have had), both 170 and 180 are stamped "made in Germany", not USA (enlarge the image) like in the picture here.
Go figure.
A little more than a degree or two. Its a 195.
Good info,I didn't know they were the same.So the $15 Autozone part is the same as the $30 Summit part?
Quick and maybe stupid question but, can you run these in cold weather?? And does it make a real difference if im running a almost stock GCSRT8??
Thanks
I ran my 180 last winter with no problems, we also had lots of really cold days. My stock stat has 203 degrees stamped on it. but when I was looking for a new 180 last week, I called the dealer and they told me they only had 195 replacements.
195 sounds better to me, unless you do a tune for thermostat then you could run the 180 i guess.....
driving mine today it barely got to the 215is mark a couple times.... its stock too
can somebody post the motorad part number please...can't find it in stores for some reason
Sent from my EVO using AutoGuide App
autozone/advance auto... duralast/motorad pn is 4128..... works like a champ and is cheaper than a jet.
Thanks colt. That's what I wanted. Not spending 40 for a 15$ part. I didn't know the duralasts were the same as motorad...so three manufacturers, three part numbers but one identical item.... Hmm hah
Posted the jet # so you could cross it for the motorad. Autozone would be able to do that.
Just because motorad makes it does not mean it the same
Here I compaired the OEM, 4127 and the Jet
http://www.cherokeesrt8.com/forums/showthread.php?t=15166
As you can see the jet has motorad on it
Some one throw a picture up of the 4128 to compare it to the jet I have pictured please, wonder if it the same as the 4127 just with a different temp range or if it is in fact just like the jet
No I appreciate it Jim. I know why you posted. Autozone couldn't figure it out with the 10183 number. Must be the weather lol
So the 4128 is the right one for 180 degrees? What's the 4127? Oem temps?
1 - 20 of 26 Posts
