1 - 6 of 6 Posts
What should it cost me to install Eibach Springs on my Jeep?
If you have the palce and some basic tools, do it yourself. the install is easy. Where are you located, I'm sure there is someone local that may be able to help too.
There is also a write-up somewhere around here.
Springs are pretty easy, I haven't dont one Jeep but done many other cars..
I also hear that you don't need spring compressor for jeep which makes the job 10 times easier
usually spring job is350 or400
I think if someone is charging you $400 to install springs on the Jeep, you better find someone else! It should take about 2 hours max...at $80 hr. that would be less than $200.
Just had mine installed today.. $279+$100 for alignment
sorry, I meant alignment as well...
1 - 6 of 6 Posts
