As far as I figured out, this is a knock on the right head, 1 left side, 2 rightjump up to 5v, primarily bank2
Please look at my logs, it seems to me that the knock does not depend on the settings and therefore I think it is not real.Ok I believe this is definitely true knock, because the knock sensor voltages are normal after warm up.
6.4s are known for low speed knock but this is too much 9° at 21% TPS is not normal.
1-2° short term knock is normal with initial tip in, and between shifts at WOT.
Do you have a tune? If yes, send me a link to your HPT post I'll go take a look.
I have sent you an emailOk I believe this is definitely true knock, because the knock sensor voltages are normal after warm up.
