OK like most (all owners) I'm chasing overheating heating issue Gremlins SO...cold case radiator, new upper lower hoses, new stock tstat, good fluid and new fan relays.
Temp gun at tstat housing reads 195- 200, temp gun on upper hose reads 190, BUT on the coolant temp sensor or as close as I can get it ...I get 225 ! Help, I have a new coolant sensor ready to put in but that seems not to be an issue as its reading what it is at that point on my engine. Only thing I have not replaced is water pump, I think.
From the original it runs fine 215 at low speeds and even sitting in traffic, but 70 plus the temp goes up. I do have blow off at the radiator cap and have ordered a new cap from Cold Case.
I dont think that I have air in the system, but have not had it professionally purged, beside me taking out the bleed valve, filling it then filling more and idle to let the bubbles out at the reservoir.
