1 - 11 of 11 Posts
anyone know about an up and down hood adjustment on the hinges?? i had the v2 put on and the driverside is a little higher then the corner panel?? help!!!
You can slide the fenders in and out, maybe they go up and down?
hmmmmm. i dint know if the bumpstop would help cause its higher on the whole side up to near the windshield
The bump stops may work. The hood kind of balances in the front center were it latches. Raise the bump stop slightly on the side opposite the high hood side.
Reactions: nyjoed
My v2 rides high on the drivers side as well. Bump stop adjustment did not help. If you figure something out, let me know! I'll do the same for you. Wes
I played with it for about 30 mins, and then gave up. It looks great the way it does, but I know it isn't "perfect". The Jeep is going to the shop for some upgrades, so I am going to let them tinker with it for a bit. I'll let you know the outcome!....lol. Wes
1 - 11 of 11 Posts
