1 - 7 of 7 Posts
ive done the rears , no problem , but i cant lift the fronts because of the wing mirrors , how do i get them off ?
Discussion Starter · #2 ·
anybody????????
· Super Moderator
You are in the wrong forum. You have a wk1.
And it's been fixed.
Hey Brian, I assume you're talking about the chrome strip against the glass? If so there is a tab on the trim piece that sticks straight in on the door handle end. Pull out and up right at the end then the rest should come straight up. You may need to pry it up with something, gently...and roll the window down first. It'll just pop back out from under the mirror trim.
yes mate , the handle end comes up and off no problem , but the end under the mirror wont budge , i dont want to yank it off incase i break tabs
No tabs on that end and on mine it only sticks under the morror trim about 5/8". I took it off no probs without removing the mirror. I can take a pic of a spare trim piece I have if that'll help.
1 - 7 of 7 Posts
