1 - 7 of 7 Posts
Hey does anyone know what to set the BAP to on a Vortech V3 kit? The rest of the Jeep is stock, even exhaust.
Also do you guys run the pressure switch or do you put it together and run the BAP all the time? If so how did you set it up and install it?
I need some advise please.....anyone?
Run the pressure switch,do NOT run it all the time without the switch.
Discussion Starter #4
Thanks for the replies guys, I had been waiting but we installed it already with the pressure switch. Yes it came with directions but many different opinions on whether it should run all the time or not, yo use the switch or not. The install instructions were with the Vortech set up so it was made for the other BAP and not the Kenne Bell we installed, that's why. Thanks!
Yeah,if you don't run the switch the pump will be running at that higher voltage all the time,even when idling. That will kill your pump very fast. Just ask Vinny.
Miss Understood
yep if someone tells u to not run the switch ur pump will did in 2000 miles and it sucks
Discussion Starter #7
I'm glad we used the switch, my mechanic was behind that idea 100% too
1 - 7 of 7 Posts
