1 - 3 of 3 Posts
Hello, I woke up this morning and my window to my Jeep was broken. I thought it was just broken so they could steal something inside the truck but they attempted to steal the actual truck I can tell because now the truck will not turn on because it says the key is not found (even though i have the key with me. Please give me any suggestions on to to fix it
Maybe try disconnecting the battery?
It's under the passenger seat and a pain to get to but there is this + terminal under the hood.
You could disconnect the + to the car and reconnect it. It only takes a few minutes.
It won't upset anything I've done it before for other reasons.
If you have to move or tow it you can unlock the electric transmission.
Under the cover in the back of the console is a cable release.
Push the small unlock slide with your key and pull on the lever all the way.
To put it back push the lever back in until the unlock slide goes back into the lock position.
Becareful, they might've tried to reprogram the key so they can steal it. In that case you may need to visit dealership, so they can look at it.
1 - 3 of 3 Posts
