Help needed
719 Views 10 Replies 4 Participants Last post by  WUNFSTSRT
I have a 2014 Jeep Srt with a Ripp sc and approximately 60k miles. The other day I started the car and it sounded like metal in a washing machine. I immediately turned it off and checked to make sure nothing was visibly wrong. All looked normal so I started it again and heard a slight tick. I pulled it to the bottom of my driveway and topped off the oil that was about a 1/4 quart low, obviously not the issue but did it anyways. The I let the car idle 5 minutes and it seemed normal, although I was suspicious I drove it up my street and about 3/4 of the way up it made the same awful sound and the motor died. Strangely there were no codes registered or pending. When I attempted to restart it to bring it back home it took a bit as the first few attempts it sounded like there was no fuel and the motor cranked but didn’t start. After about 2 minutes I tried again and it started. The valve tick was there and very predominant. I immediately parked car in my garage and started doing some research. I first thought it was possibly a frozen lifter but from what I’m reading there nothing that matches up with what I experienced.
Since then I have run a compression test and all cylinders are pulling 225 and the oil pressure is good. All spark plugs are intact and look fine, I had installed them about a month ago. I drained the oil and there was a small spring which looked like a valve seal but all of mine where intact when I removed the valve cover. I’m really hoping someone on the forum has some pointers because I’m at a loss and need to get my daily back up and running.
Sleeve Collar Finger Gas Wrist
Hand Body jewelry Finger Gesture Thumb
1 - 11 of 11 Posts
I had a Pro charger seize on me once, I thought the engine was toast, but it was the blower that was seized, shortly before it went it had a strange wine to it. I took the belt off and the engine fired right up and was fine. Let's hope its the blower in your case but if you have a stock engine I'm willing to bet something in the engine got damaged. The stock 392 does not do well on boost, either the lifters or the pistons will go eventually.
I have no clue what that spring is from!
I had a Pro charger seize on me once, I thought the engine was toast, but it was the blower that was seized, shortly before it went it had a strange wine to it. I took the belt off and the engine fired right up and was fine. Let's hope its the blower in your case but if you have a stock engine I'm willing to bet something in the engine got damaged. The stock 392 does not do well on boost, either the lifters or the pistons will go eventually. I have no clue what that spring is from!
I was hoping the same but unfortunately after removing the belt the sound was still there. Should have the heads off tomorrow and I’ll know more.
Found the problem…. Hoping someone might have an idea why this would happen.
Hand Gas Automotive tire Wood Metal
Musical instrument Guitar accessory Crankset Hat Finger
Automotive tire Wood Gas Automotive wheel system Wood stain
No, this was a stock block with about 50,000 miles. The SC was put on when the car had 15,000 miles. This wouldn’t be considered a ring land failure with it?
I hear the 6.4s can't handle much boost due to the thin ring land, which would break easily if the top ring expands to the point were it would bind... That could be due to too much boost, too much timing advance, or a lean AFR.
Why are you bumping this?
It's obvious why they tell people not to run boost on these engines or any engine that is not built for boost!
To be honest, I didn’t even realize I had replied to this thread.. I hate to say it, but I’ve been there done that and know the cost of running boost stock engine.
Haha I'm just busting your balls lol 😉
1 - 11 of 11 Posts
