1 - 5 of 5 Posts
Guys, so I was replacing the pads yesterday on my 06 GC SRT8. I was also bleeding the brakes. When I was trying to unscrew the bleeder valve on the passenger front calliper; It was very difficult to unscrew and broke off. Thank goodness it was still closed. So does anyone know where I can order a new Bleeder Valve Screw and what the process would be to replace it?
Is it just a matter of drilling out the old one with an extractor and putting the new one in? Any help would be much appreciated. Thanks!
To get the old one out go to autosomal, NAPA or wherever and get a screw extractor set. You drill a pilot hole through the center of the screw then use the extractor in reverse in your drill. It bites inside the hole and pulls it out.
Probably try the dealer or Brembo direct on a replacement.
You can get new bleeders screws at the parts place you buy the extractor from.
Reactions: StangSlayerMA
1 - 5 of 5 Posts
