Try this tire calculator to figure what will work. You want the diameter and circumference to be within 3%.
http://www.miata.net/garage/tirecalc.html
first off thanks for this site! second, when you say 3% is that where it says "non-stock tire is x.x% too slow" ?? because when i put in my 245/45/20 - 255/45/20 (which ive at the moment) it says 1.2% ??? very confusing tbh as ive never really understood wheels tires etc;Try this tire calculator to figure what will work. You want the diameter and circumference to be within 3%.
It gives you an actual measurement you have to do the math to determine if its less than 3%oh hang on...it says "too slow" for my current set up ...and for 255/45/20 - 275/40/20 "too fast" ....right i think im kinda getting it, so it must be within 3% "too fast" ?
HAHA ...ehm...any help with this one?!you have to do the math to determine if its less than 3%
I do know he has 275/40/20 in stock and are the same tires! because i checked them out, so possibly them...as you said that looks like the closest....but if you able to calculate it for me and tell me what the best is....265/x/20 or 275/x/20Ill see if I can figure it out for you but I need to know what tire sizes you are thinking about using. Do you know what you have available to you? Also I would recommend keeping with the same brand if not the same model of tire if possible
