1 - 6 of 6 Posts
can you elaborate more on where exactly it is hitting. is it always in contact or only when you hit a bump ?
pics would be ideal. sounds like improper installation to me
Sounds like your control arms are making contact with the shock tower. This is why the bumpstop is there. How much did you trim the bumpstop? I think you need to put a stock bumpstop back on.
Sounds like your control arms are making contact with the shock tower. This is why the bumpstop is there. How much did you trim the bumpstop? I think you need to put a stock bumpstop back on.[/Q
I cut 1" the bumpstop and i check the gap between the bumpstop and the shock with the jeep in the floor is about 3/4".I am getting crazy:flame:
Please any solution
Go back to the stock bumpstop. 1" is way too much to cut off. I cannot tell you how much is tolerable. Maybe start with 1/2" or less? It's yours to experiment with.
1 - 6 of 6 Posts
