Do you have the HID option on your 08 or do you have just standard halogen bulbs ... an easy way to tell is - do they light up with a yellow tinge or are they very white with a hint of blue ?
If you have normal halogen bulbs its p/n 9006 and shouldn't be more than a hand full of bucks from your local Auto parts store ( I recommended changing both sides at the same time ) if its the DRL/ high beam bulb then its a 9005.
As far as the HID's go, im not too sure what the OEM p/n would be as I have aftermarket bulbs in mine
If you have the OEM HID projectors it is pretty easy assuming you are referring to the low beam.
Remove the big rubber cap on the back of the light, release the clip, remove "bulb", unplug "bulb".
And do the reverse for install.
I have bought D1S bulbs for the low beam in OEM HIDs before from Steve at Xenon Depot as I slightly changed the color of the light.
If it is the high beam, it is even easier.
Be sure not to touch the bulb with your fingers either. You can touch the metal base...just not the glass tube.
They are tiny. Right in the middle of the plug on the side facing the glass tube (top) and bottom side if I remember correctly. Almost need to use your nails to push them in if you have bigger hands/fingers.
