1 - 2 of 2 Posts
have factory manifolds and just Made new exhaust from the stock manifold back. I usd the factory flange that bolts to the manifolds on both sides building the new exhaust ( 3" stainless )
I basically cut the flange about 3" Down streams and tig welded the old factory flange sections on.
This is the problem , the inside of the original flange that bolted to the manifolds appears to have had a metal fiber seal ( makes Sense to form the seal)
this has become worn thru from pulling on and off fitting exhaust .
For the life of me I can not find this contoured seal , gasket, donut whatever jeep calls it. 2015 SRT if it makes difference but the manifolds appear to be used across multiple years.
What is the seal used from the factory .....from the stock manifolds where they bolt onto the exhaust flange, has to have had something in there; as I said appears to be a fiber metalized thin gasket that seals the manifold to the exhaust flange
on both sides.
Help
Thanks in advance guys
Did you ever find the part number or a replacement?
1 - 2 of 2 Posts
